How to decide the fanout?
mic_huhu
Member level 3
Hi,everybody,
I don't know how to add fanout number in the DC constraints file.
who can help me?
Thanks
JOhnny
jinruan
Junior Member level 3
i can find the default value in your process library,
and you can define the value according to your design based on the value
Thomson
Full Member level 3
By default, the synthesis tools such as Design Compiler will synthesize your RTL coding according to the fanout requirements of your techonology file(you can refer to your techonology file). Often, for the accuracy and P&R, we can set a smaller fanout limit than that in the technology file so that you can obtain a faster circuit and less area and routing congestion( please note the cell-based P&R, if using a very large one instead of several smaller ones the routing is not so easy and good). Aditionally, you should set the output pins' fanout/capacitance value according to the context environment of your design which should be perceived of during the design division process. Finally, if considering the pads, then you should ask some infomration from your system designer who will give some requirements about the pads such as the input delay/capacitance on the pads and output delay/capacitance on the output pads and so on.
power-twq
Full Member level 6
you can set a arbitary value and perform a pre-synthesis.
then look for actual fanout value from generate netlist,
then set actual fanout value and re-synthesis.
mic_huhu said:
Hi,everybody,
who can help me?
Thanks
JOhnny
lijian_18
Actually, the default number in Standard Cell Library is sufficient unless you have your specific reason to override this.
