How to decide how many layers you need in PCB application?
g_iftah
Junior Member level 3
Israel
PCB layers
hi...evry one......
does any one know how do you decid how many layers you need in an application.
lets say for start that it has anlog and digital parts....
binu G
Advanced Member level 2
Bangalore
PCB layers
if there are multiple voltages then how the layer stack up is designed.
how the ground layers are distrubited in this case.
binu g
g_iftah
Israel
Re: PCB layers
i am sorry didnt quit anderstand you....
i have 5V input and 3.3 after converter and regolator+
i have anlog part sach as codec and microfone + bluetooth baseband controler+digital cpu.....
i am thinking somting like 5 layers am i rigth or can you make less??
binu G
Bangalore
Re: PCB layers
g_iftah
Normally the layer stackup is even number.
Binu G
House_Cat
USA
Re: PCB layers
You decide how many layers you need depending on what you are trying to do with the circuit. You might need only a single sided board for a simple project, or you might need 4, 6, 8, 10, etc. layers for more complex circuitry.
The number of signal layers and the number of planes are each used in symetric pairs in a multilayer board. For multilayer boards, in general, you typically would have a ground plane, and a power plane. The power plane can be split to supply more than one voltage. These two plane layers would typically be in the center of your stackup.
The next layers out from the center would be signal layers. Critical signals would be run on the layer adjacent to the continuous ground plane - the trace width and the distance between the signal layer and plane would be chosen to give you the desired impedance for the signal traces. Less critical signals such as display traces, relay control, etc. could be on the layer adjacent to the power plane layer.
Analog and digital traces would be laid out such that they are separated physically, and do not share any areas of the adajcent plane. The reason for this is to avoid having shared signal return paths which could couple noise from digital to analog circuitry. Try to visualize each signal path as a complete loop consisting of the trace on the signal layer, and the return part of the loop through the adjacent copper on the plane.
Additional planes, and signal layers, would be added in pairs as needed to accomplish the desired routing.
There is no cookbook answer - you use your engineering knowledge to figure out what will give you the best results for your project - signal by signal.
    g_iftah
cube007
Full Member level 6
Australia
PCB layers
The number of layer depends on different things: Speed of the signals, device packages, space for placing the devices. For example if you are using a BGA you will need at least 4 to 6 layers. The less space you have for placing your devices the more layers are needed. For digital high speed designs you will need proper power planes.
yangvic
Member level 2
PCB layers
You can refer your main chipset's application note.Sometimes it will discuss this.
tennad
Junior Member level 1
PCB layers
A table you can refer to
pin_density signal_layer PCB layer
>1.0 2 2
0.6-1.0 2 4
0.4-0.6 4 6
0.3-0.4 4 8
0.2-0.3 6 10
<0.2 8 >14
PCB density = PCB square(sq inch)/(pin sum./14)
amjad
Full Member level 5
Re: PCB layers
Number of layers depends on how much design complexity is the circuit, and how much signal layers required to complete the routing of nets and number of planes for power and gnd separations irrespective of the board area required for laying the component placement .
Also board thickness is considered before deciding the number of layers that the thickness can accomadate .
