How to deal with design issues connected to nanotechnology
ameed
INDIA
hi all,
At the sub-nano technology nodes, the impact design-process interactions have on yield is becoming a huge factor and is very design-dependent. Expecting a designer to understand the nuances of the sub-nano process issues, and the process engineer to understand the design issues is very optimistic, but not realistic. Making sure that a design is less sensitive to litho and other layout-related yield loss issues is critical. One way to address this is to,
1. Give up the traditional independence and build better "inter-dependence" between the design and process teams:D
2. Jointly capture the required process intelligence and encapsulate them into design tools:D
3. Build the required automation into the tools to address the sub-nano issues right from the cell-library development stage of a flow:D
The advantage of addressing at the cell library level helps take care of these issues once, and not on a per design basis. Such a tool would enable layout designers with little or no process expertise to create DFM-optimized designs, by automatically addressing litho and other layout-related yield considerations like contact doubling and random defect sensitivity.
An automated tool that allows encapsulation of process intelligence to produce high-yielding library elements at sub-nano conditions is now available. Use of such DFM-optimized libraries would take away the pain for the downstream IC designer.
thanx.
