AndreyG
Full Member level 4
- Joined
- May 10, 2010
- Messages
- 196
- Helped
- 27
- Reputation
- 54
- Reaction score
- 27
- Trophy points
- 1,308
- Location
- Vancouver, Canada
- Activity points
- 2,946
How to de-couple feed cable for measurements of electrically small wide band antenna?
I normally use bazooka-type coaxial balun to decouple feed cable. In this project bandwidth is large (0.85 - 2.1 GHz) and bazooka balun does not have the required bandwidth to cover the band. Plus antenna assembly is pretty small, significantly less then the choke will be at low frequencies.
I thought to use ferrite beads but they absorb energy, I see it with NA.
Did anybody encountered this problem?
Thank you
Thank you
