when I want to use Lumped Ports in HFSS do I always need to put a layer as a reference ground? Since I need S parameter results I would like to use lumped ports but in my structure there is no layer gnd below the input port and the problem is that without gnd layers it doesn't work! Is there another way, differet from the figure, to create lumped ports?
Lumped_port is a "localized" source. Some people call it a differentiall source. The ground plane is not part of its definition. You don't need to define a reference plane for a lumped port.
However, in the picture you sent, the lumped-port is "floating"--like a battery with wire attached to only the positive end, while the negative end is just hanging. The "battery"--the lumped port--is well defined, the "circuit" is probably not.
Thanks for your help, so loucy you mean that I don't need to insert a reference plate but as you know when you define a lumped port it asks to specify the conductor layer and the reference layer. So my question is which kind of reference can I define?
In my structure I have a part of the circuit that has a metal layer as a gnd below it, but there is also another part that has no gnd layer below. The last part is my problem!
Thanks a lot!!
