how to create .io file for layout
siva_7517
Full Member level 2
cadence encounter iofile
hi,
I am using cadence encounter for my layout design. Can i know how we can create a .io file for layout. I need this to locate my pad cell and filler pad for design but dont know how to crete this file. hope anyone can help on this.
Siva
joe2moon
Full Member level 5
MOON
how can i create .io file in encounter
First, you can import the design into Encounter to let FE place I/O pads automatically.
Second, write out the IO file using FE.
Third, manually edit above IO file according to your requirement.
ps: IO Filler cells do not have to be put into the io file, and can be placed later inside FE.
hltong
Newbie level 5
how to create io file encounter
Yes . You can place IO Cell randrom . then write the file ioplace.ioc and manual edit it . reload the file . It will OK.
