How to convert VHDL code to Verilog?
mithri
Junior Member level 2
hi everyone,
I have written my coding in VHDL using Quartus-II SOFTWARE.for a particular application i need it in VERILOG code.can i directly change my vhdl to verilog r do u need to write in verilog again.
i will be thankful if u can reply me as early as possible
vhdl2v
There is a program called vhdl2v that converts VHDL vode to verilog code.
the program is free, you can download it from this link
http://www.ocean-logic.com/downloads.htm
this tool is not perfect, but give it a try.
Reactions: tariq786
    mithri
    tariq786
download x-hdl -crack
thanks for your help !!
but would you like give me some advise on the use of the program!!
for example ,what can I use to open the program,thanks again!!
    mithri
vhdl to veri log converter xhdl-tek free download
and what about verilog to VHDL ?
i would need that
    mithri
vhdl to verilog converter free
Hi vfdff, File vhd2vl2.tgz is a source archive. You need to unpack it with tar and gzip (WinZip or WinRAR can do it), and then compile it with flex, bison, and gcc.
I built a Windows executable with MinGW (attached below). Most of the example conversions work fine, but one of them crashes and another gives different Verilog output. I ran into a few snags during the build, maybe that's why. Or maybe the program simply has bugs. I also tried building it under Cygwin, and got slightly different imperfect results.
    mithri
tek corp xhdl
Hey all.......
X-Tek corporation X-HDL is a bi-converter....Verilog <-> VHDL....
    mithri
xhdl trial version download
hi kpsai26779
you can register on their web site and download a limited demo version of x-HDL
their web site is:
https://www.x-tekcorp.com/
regards,
sakr
    mithri
Re: VHDL TO VERILOG
Guru59 said:
Hey all.......
Yes, X-hdl is a good tool for translating between VHDL and Verilog. I have used it to translate many codes and it works well.
    mithri
Re: VHDL TO VERILOG
you can use Summit tools (now mentor graphics) to conver VHDL to Verilog...
    mithri
Re: VHDL TO VERILOG
i am downloading x tex already but it say that the file too big to transfer ,what the problem ?
Re: VHDL TO VERILOG
yes i'v the same prblms, i cnt translate it for big programs,
what i shoudl do??
Re: VHDL TO VERILOG
If it's the free version of this tools, then it has limited capabilities (big files can't be handled in the free version).
It's expensive to buy, but it works quite well.
BTW most of today's FPGA tools can handle mixed signal (with a wrapper) source code.
Regards
I just sent a request for a quote to X-Tek for their X-HDL software. I'm assuming that since they don't list the price on the website, it's probably pretty expensive. But I'm curious, so we'll see. When I get the quote I'll post here so we can all have a idea of the cost.
can anybody explain how to use the xhdl?i already download it but i dont know how to use it...T_T
