How to convert .v library to .lib or .db ?
omara007
Cairo/Egypt
Hi folks
How to convert a ".v" library into ".lib" or ".db" using Synopsys Memory Compiler ?
HolySaint
Full Member level 3
Mars
U can use DC
first read_verilog ***.v
then write -format db -output ***.db
this is lib2db example
read_lib ***.lib
write_lib TOP_MODULE -format db -output ***.db
avimit
Banned
Fleet, UK
.v library files are simulaiton library, they do not have the same information as your techlib file .db or .lib has. So you cannot convert a .v library file into a .lib or a .db as a technology library.
Hope it helps
Kr,
Avi
kumar_eee
Advanced Member level 3
Bangalore,India
.V files are your verilog models. If u want to create .lib files, u need to have layout. U Need to run Library Compiler to generate .lib files.
