How to convert the db file gtech.db to gtech.v format?
rsrinivas
Advanced Member level 1
bengalooru
Hi all
i need to convert the db file gtech.db to gtech.v format
is it possible?
pls let me know
thanks in advance
srinivas
db format to verilog
hello Srinivas
I have nver read any where if this is possible, The reason wat I could deduce is .. The bd format which we get after synthesis steps involves various other details of timing and delay. But the verilog r VHDL file do not involve all these details amy be tat is the reason we have the option of writing out both .db and .v files ..
This is according to me .. but please let me know if i am wrong .
suresh
hi All,
the gtech.db is the genric technologie librarie.in the directorie of the synthesis tool you can also fine the gtech.v/gtech.lib .
if you are talking about the netlist write in the formate of .DB the you can read again it in the synthesis tool and link it and you can now write out the .V netlist file from the tool.i think it will solve your problem.
BR,
Ramesh.S
Ask Synopsys. They can answer u better.
Sumit
Re: db format to verilog
Hi!!!
in dc_shell
read -format db {name.db}
write -format verilog -output name.v
U can never convert .lib format to verilog(.v) format in Design compiler.u can convert into vhdl format..
Shurik is correct, however, the output verilog will be in gtech library.
