How to convert PIC18F ASM code to C code?
ful babu
Full Member level 3
Singapore
i want to convert a PIC18F asm code to c code, is it possible ?
thx
mgajo
Full Member level 2
convert assembly to c pic18f
NO
metal
Full Member level 6
convert pic18 to c
Hello
This is a weired question indeed, because most companies, if not all, will not bother themselves making any thing that converts ASM code to their C code recognized by the compiler.
As you know, C, Basic, Pascal compilers use what is known as ASM code blocks, so that when you write a C code for example, and then compile it, the compiler simply recognizes what commands you have written, and checks rules to see if there are any mistakes, if you are a lucky guy, then the compiler will add those ASM blocks together to form your ASM code equivalent to what you really want to do, then using an assembler, it will generate the HEX code...
Bear in mind that there are many ways to do the same job, for example, if you want to move from one bank to another, you can simply write:
BSF STATUS,RP0 ;Moving to bank 1
or, equivalently, you can also write:
BANKSEL PORTB;Moving to the bank where PORTB register exists
From this, you can see that its seriously difficult, if not impossible for the company's profit point of view to even think about it.
ful babu
Full Member level 3
Singapore
pic18f1320 code asm
well i tried to bother to convert because , i wanted to use a asm block in hitech18 c compiler which has some loop, but it shows some error, which perfectly compiles in MPLAB, any idea how to do such asm blocks ?
like this one ...
GOTO _28
_08:
BSF 0xfac, 0x5
MOVLW 0x90
MOVWF 0xfab
BSF 0xf94, 0x7
BCF 0xf94, 0x6
_12:
CLRF 0
CLRF 0x1
BTFSC 0xf9e, 0x5
INCF 0x1, F
MOVF 0x1, W
SUBWF 0, W
BZ _26
MOVF 0xfae, W
MOVWF 0x15
BRA _12
_26:
RETURN 0
_28:
MOVLW 0xc
MOVWF 0xfaf
BSF 0xfac, 0x2
CALL _08, 0
thx
