apekesmaster
Newbie level 3
i got a code .pbp but i don't know how to read it anybody can help me to convert this code to .asm code
'~~~ 245 LED PC-Programmable Moving Message Display By Trent Jackson ©2006 ~~~
' Version: ßeta 0.1 '
' Project started: 20/05/06 '
' Finished: 21/05/06 '
' Bugs & Enquiries: trentjackson888@bigpond.com.au ' '
'Target: PIC 16f628
Include "modedefs.bas" 'Include serial modes
Define OSC 10 '10MHz crystal
CMCON = 7 'Disable comparator, start up in digital mode, PortA
'----------------- Row Control ----------------
'PortA: Pin1, RA2 = ROW 1
'PortA: Pin2, RA3 = ROW 2
'PortB: Pin6, RB0 = ROW 3
'PortB: Pin7, RB1 = ROW 4
'PortB: Pin8, RB2 = ROW 5
'PortB: Pin9, RB3 = ROW 6
'PortB: Pin10, RB4 = ROW 7
'--------------- Column Control ---------------
'PortB: Pin11, RB5 = Master Reset 4017 Counters
'PortB: Pin12, RB6 = Clock Cascaded Counters
'--------------- Serial EEPROM ----------------
'PortA: Pin18, RA0 = Data Line
'PortA: Pin17, RA1 = Clock Line
'-------------- Communications ----------------
'PortB: Pin14, RB7 = RX Line
'PortA: Pin3, RA4 = Program Button & RX LED
Setup:
'Define port pins as inputs and outputs...
TRISA = %00000000
TRISB = %10000000
'Variables...
EEPROMAddress VAR WORD
MSGLength VAR WORD
ScaleTime VAR WORD
DataBuffer VAR BYTE
EEPROMConfig VAR BYTE
ColPosition VAR BYTE
ToggleLEDRate VAR BYTE
ShiftMSGSpeed VAR BYTE
CycleMSGTimes VAR BYTE
CycleCounter VAR BYTE
EEPROMDataPin VAR PORTA.0
EEPROMClockPin VAR PORTA.1
ClockColsCounter VAR PORTB.6
ResetColsCounter VAR PORTB.5
ROW1 VAR PORTA.2
ROW2 VAR PORTA.3
ROW3 VAR PORTB.4
ROW4 VAR PORTB.3
ROW5 VAR PORTB.0
ROW6 VAR PORTB.2
ROW7 VAR PORTB.1
ProgButton VAR PORTA.4
ActivityLED VAR PORTA.4
'Defaults
EEPROM [1,0,0,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
'Init
EEPROMConfig = %10100000
INPUT PORTA.4
'Load moving message speed rate - (user-definable in Windows GUI)
READ 0, ShiftMSGSpeed
'Load message length & cycle times
READ 1, MSGLength.BYTE0
READ 2, MSGLength.BYTE1
READ 3, CycleMSGTimes
'Reset 4017 counters
ResetColsCounter = 1
PAUSE 100
ResetColsCounter = 0
'Starting address
EEPROMAddress = 1
RunMessage:
'User pressed program button?
IF ProgButton = 0 THEN GOTO ProgramMessage
ColPosition = ColPosition + 1 'Inc
IF ColPosition = 37 THEN ColPosition = 1 'Reset
'Fetch data from EEPROM
I2CREAD EEPROMDataPin, EEPROMClockPin, EEPROMConfig, ((35 + EEPROMAddress) - ColPosition), [DataBuffer]
'Switch off all rows during the transition of the clock signal to the counters, this eliminates trailing
ROW1 = 0
ROW2 = 0
ROW3 = 0
ROW4 = 0
ROW5 = 0
ROW6 = 0
ROW7 = 0
'Clock cascaded counters
ClockColsCounter = 1
PAUSEUS 1
ClockColsCounter = 0
'Inc address, fetch next
IF ScaleTime = ShiftMSGSpeed THEN
EEPROMAddress = EEPROMAddress + 1
ScaleTime = 0
ENDIF
IF EEPROMAddress = MSGLength THEN
'A setting of 255 for the number of cycle periods denotes a continous loop
IF CycleMSGTimes <> 255 THEN CycleCounter = CycleCounter + 1
'Has the number of cycles been reached?
IF CycleCounter = CycleMSGTimes THEN
'Reset counters
PAUSE 50
MSGFinished:
'Infinite loop until user hits reset button
PAUSE 200
GOTO MSGFinished
ENDIF
EEPROMAddress= 1 'Reset
ENDIF
OutputRowData:
'Logically AND retrieved data from EEPROM with row bit values and write to port asynchronously
IF DataBuffer & 1 THEN ROW1 = 1
IF DataBuffer & 2 THEN ROW2 = 1
IF DataBuffer & 4 THEN ROW3 = 1
IF DataBuffer & 8 THEN ROW4 = 1
IF DataBuffer & 16 THEN ROW5 = 1
IF DataBuffer & 32 THEN ROW6 = 1
IF DataBuffer & 64 THEN ROW7 = 1
'The multiplex rate is about 23Hz duty cycle is about 2.8%. Some deliberate flickering results
'from the low multiplex rate. This allows for extra birghtness from the LEDs. The duty cycle is so
'low that this lower than desirable rate is the only real option...
PAUSEUS 100
'Generate increments from the 100us delay to be used with the actual moving of the message speed
ScaleTime = ScaleTime + 1 'Inc
GOTO RunMessage 'Loop back
ProgramMessage:
'Make PORTA.4 an output so that the activity LED can be flashed
OUTPUT PORTA.4
ActivityLED = 0
EEPROMAddress = 1
DataBuffer = 0
ROW1 = 0
ROW2 = 0
ROW3 = 0
ROW4 = 0
ROW5 = 0
ROW6 = 0
ROW7 = 0
WriteToEEPROM:
'Now, write contents received serially from the PC to the EEPROM
SERIN PORTB.7, N2400, ["a"], DataBuffer
IF DataBuffer = 255 THEN GOTO WriteMSGLength
ToggleLEDRate = ToggleLEDRate + 1
If ToggleLEDRate = 4 THEN TOGGLE ActivityLED: ToggleLEDRate = 0
I2CWRITE EEPROMDataPin, EEPROMClockPin, EEPROMConfig, EEPROMAddress, [DataBuffer]
GOTO WriteToEEPROM
WriteMSGLength:
MSGLength = (EEPROMAddress - 35)
WRITE 1, MSGLength.BYTE0
PAUSE 5
WRITE 2, MSGLength.BYTE1
WriteCycleTimes:
PAUSE 5
'Save cycle times
WRITE 3, DataBuffer
PAUSE 5
'Now load it
WriteCycleSpeed:
PAUSE 5
'Save cycle times
WRITE 0, DataBuffer
PAUSE 5
'Now load it
NoMoreDataToWrite:
'Reset and return to main routine
PAUSE 100
EEPROMAddress = 1
DataBuffer = 0
ColPosition = 0
CycleCounter = 0
ScaleTime = 0
INPUT PORTA.4
GOTO RunMessage
END
'Target: PIC 16f628
Setup:
TRISA = %00000000
TRISB = %10000000
'Variables...
MSGLength VAR WORD
ScaleTime VAR WORD
DataBuffer VAR BYTE
ROW1 VAR PORTA.2
ROW2 VAR PORTA.3
ROW3 VAR PORTB.4
ROW4 VAR PORTB.3
ROW5 VAR PORTB.0
ROW6 VAR PORTB.2
ROW7 VAR PORTB.1
'Defaults
'Init
INPUT PORTA.4
PAUSE 100
'Starting address
EEPROMAddress = 1
RunMessage:
ROW1 = 0
ROW2 = 0
ROW3 = 0
ROW4 = 0
ROW5 = 0
ROW6 = 0
ROW7 = 0
PAUSEUS 1
ScaleTime = 0
ENDIF
'Reset counters
PAUSE 50
MSGFinished:
PAUSE 200
GOTO MSGFinished
ENDIF
ENDIF
OutputRowData:
PAUSEUS 100
ProgramMessage:
OUTPUT PORTA.4
ActivityLED = 0
EEPROMAddress = 1
DataBuffer = 0
ROW1 = 0
ROW2 = 0
ROW3 = 0
ROW4 = 0
ROW5 = 0
ROW6 = 0
ROW7 = 0
WriteToEEPROM:
GOTO WriteToEEPROM
WriteMSGLength:
PAUSE 5
WriteCycleTimes:
PAUSE 5
'Save cycle times
WRITE 3, DataBuffer
PAUSE 5
'Now load it
WriteCycleSpeed:
PAUSE 5
'Save cycle times
WRITE 0, DataBuffer
PAUSE 5
'Now load it
NoMoreDataToWrite:
PAUSE 100
EEPROMAddress = 1
DataBuffer = 0
ColPosition = 0
CycleCounter = 0
ScaleTime = 0
INPUT PORTA.4
GOTO RunMessage
END
