How to convert Hexa code to Assembly format?
ekh_81
Newbie level 6
Help Hexa to Assembly
Hi
I have a problem, i want to convert a hexa code to it's original assembly code. Does any one can help me.
Thank you in advance.
It might help if you gave som info on the micro this code is used for. Normally you'll need a disassembler to do this.
TOK ;)
Re: Help Hexa to Assembly
The hexadecimal codes are pure translations of the assembler mnemonics, as such the MOV ah,bh instruction (intel assembly) will always compile to the same hexadecimal bytes. To regain the original assembler a dissasembler is required, if you have the time you can write your own, or do it manually by hand. Obviously the dissasembler is the easiest option, although no insight is gained in the assembler -> hexadecimal comilation process. The conversion data can usally be found on the manufacturers website/ databooks
cheers
slayerza
Thank you for your answer, this code is used to program a PIC. I want to rearrange it and add and remove some instructions.
and this is the link
http://www.elektor.fr/Portals/0/Magazine/Downloads/2005/030451-11.zip
