hi how to convert +dc volts to negative dc volts. in some transformers i saw they added capacitors and i dont know what tpe of capacitors any one can help me.
More exact question please, so we can understand the problem you have.
You should tell us voltage and current you need and what is the input voltage to converter,
or are you thinking to reconstruct power supply with transformer. ????
Or do you ask the general principle to do this conversion???
hi
i have 6volt dc supply fm board, so i took 240AC TO 6-0-6 volts step down transformer, but in that board they mentioned + and - symbols(ground). in that case how do i convert +6 volt to -(ground).
---------- Post added at 18:32 ---------- Previous post was at 18:31 ----------
hi
Here is principal power supply.
Component values depends on needed current.
Regulation is poor due to transformer voltage should be 8Vac.
If your board can accept 8.5Vdc , you dont need regulator.
( Voltage without regulation can change in 7.5....10Vdc depends on transformer and 240Vac supply.)
If you have 6-0-6 volts transformer it is much easier to build a split supply (i,e; plus-minus). Here is an example for you. When you rectify the 6 volts it will be DC 8.4 volts and sufficient for your 5 volts regulators.
Hope it help. Any further question welcomed.
but i will my exact problem. i have one am/fm receiver with sony CXA1619BS IC, in that board required +6volt and -6volt, when i take power from 230 to 6 volt transformer, in that transforme how do i find + or - polarity and i need circuit diagram of board, hope i described every thing
pls help me(i am begineer of the am/fm board assembling)
