How to convert bmp in pcb design
pcbman
Member level 5
bmp to pcb converter
I use PADS. Is it possible to convert bmp logo
in ascii ? I found bmpinpcb at **broken link removed**
but I don't know if it works good.
pcbman
convert bmp to pcb
Hi PCBMAN
Here's a tool for converting BMP to protel PCB, it works well. you can convert to protel format then convert to PADs. I had converted a paper-cut drawing for our namecard PCB, the drawing is shown in our website:)
mike
www.ezpcb.com
convert bitmap to pcb
if you can convert bmp to dxf maybe import in power pcb
I use pdfcreator and pdft0dxf converter program firstly convert bmp to pdf and then convert pdf to dxf very long process but succes
if you cant work bmp2asc program you sould use this way
bitmap to schematic converter
See this post
