How to convert binary fraction to integer value in VHDL?
seffin
Indonesia
Dear friends..
I have problem with fixed point in VHDL, How to display binary fraction into LCD in decimal value?
example:
1001.10002 = 9.5 decimal
10012 = 9 and .10002 = .5 but 10002 in decimal value is = 8.
if I make an encoder for this fraction value it must require very many resource in my FPGA.
I use Spartan 3E board.
please help me..
Regards
Seffin
Can you subtract a value of 3 (8-3) from the fractional values and display
But if the value is 1001.11002 the decimal value is 9.7510
the value that result from subtraction is not true..
any body have an idea? :-(
with only 4 fractional bits, there are only 16 possible states, so it is only a 16-1 decoder, which is pretty straight forward.
Reactions: seffin
    seffin
The weight of the lowest fractional bit is 1/16 or 0.0625, so you would need four display digits to represent it exactly. If this is what you want, you can multiply with 625 and convert to decimal. Or just use a look-up table of intended representations with your selected width, as TrickyDicky suggested.
Reactions: seffin
    seffin
Thank you very much FvM and TrickyDicky for your reply... :) It's very helpful!
If I use 8 bit fraction bit, the lowest fraction bit is 1/256 or 0.00390625, but it have too many digit (8 decimal digit fraction), so how to make it only 2 digit or 4 digit without reduce fraction bit?
you now have a problem of displaying it, not with your actual data.
you will have to decide how many decimal bits are acceptable and a Look up table should suit this problem.
Reactions: seffin
    seffin
TrickyDicky, What you mean with acceptable decimal bits?
I just want to diplay like this:
99.99
if I add with 1 it will display 100.00 decimal.. but I use 8 binary fraction bits..
please help me..
use a look up table for the fractional part. You dont need to do any adding at all.
Reactions: seffin
    seffin
Ok, Thank you for all :) I'll try it.. if I have succeeded I'll let you know.. :)
