how to convert back the hex file (8051) to source code......
syteh82
converting the hex file to source
now i only have the hex code for the 8051 and how can i convert it back to its source code (op-code) ???
thanks you.....
Re: how to convert back the hex file (8051) to source code..
You have to use DISASSEMBLER and you can download it from here:
But you dont forget if pass disassamler your hex code you dont have any label.
And some source files have some trap.
Sample if use any table in source file disassambler convert all data to opcode.And your converting sourse may be wrong.
i guess it will be difficult since you don't know what language the code written
and is it code protected?
If the code is protected the hex file will obviously contain garbage (AA BB CC DD ... and so on)
"attachment removed
please NEVER upload files that are freely available at the net!!!
C-Man
ı think use this program
if you dont like it i should search in google with write "Disassembler+8051
