How to convert a microstrip line (MLIN) into equivalent meander line (MEANDER) in ADS
fadubhai
Newbie level 5
Lund, Sweden
I have to convert an MLIN which has a property of Roger4360 substrate with a length of 50 mm and width of 0.2043 for 1.7 GHz. Now I would like to make it short using Meander Line technique. But the problem is I don't know how to convert it into a Meander Line. I have looked for the Meander component in the TLines- Microstrip Component section of Agilent ADS 2009, but this component is not available over there. Can anyone help me with this problem. It will be a great help for me. Thank You.
AWR has measder line function, and you can adjust the line shape easily.
agree
In the Layout window, go to (I think) Insert, Meander Line. Put in the line width, minimum spacing, total length, etc. Click once where you want to start the line, then move the cursor around and you'll see a "ghost" line. Click again to lock down the end-point. Simple.
You can easily build your own meander model. If the lines have enough spacing and do not couple, just use lines and bends. If you want to include the coupling between the straight line segments, you can use MCLIN or PCLINx elements.
