How to convert 5V PIC16F877 output to 3.3V using resistors?
zahidkhan
I am using PIC 16F877 and i want to convert the 5V output from one ot its pins to 3.3V using resistors.how should i do it. i need to know the value of resistor and how to calculate it.
regards...
    zahidkhan
Re: steping down 5V
thanks IanP. actually i am using Lassen iQ GPS Module.which operates at 3.3V.i want to communicate with its serial ports through pic. this is the whole scenario.
Re: steping down 5V
In this instance 1kΩ resistors and 3.3V zener diodes should do the job ..
Regards,
IanP
Re: steping down 5V
You can do it with optoisolator like PC816.
Re: steping down 5V
Greetings,
Just use a couple of resistors to build a voltage divider.
Exp.
In Fig.
Vo = (5V*2.2k)/3.4k ~ 3.3V --> Vo=V*R2/(R1+R2)
Chage this according the resistors values in your hands.
Good Luck.
