how to control the motor using PWM in lpc2129
salim1103
Newbie level 6
Newbie level 6
Hi friends,
how to control the motor using PWM in lpc2129.If any body can send the code.I am using 12Mhz crystal.
be specific.. what kind of motor are you using (stepper, servo or normal bldc motors)?
It is an easy task dear. Are you using any drive or hall sensor for pole positioning and feedback system?
Your input datas ain't enough to know actual problem. What are the hardwares your using there?
This link might help you.
All the best.
http://ww1.microchip.com/downloads/en/appnotes/00899a.pdf
http://www.st.com/st-web-ui/static/...ical/document/application_note/CD00041736.pdf
All the best.
http://ficta.in/attachments/article/55/06%20Control%20of%20BLDC%20motor%20with%20the%20help%20of%20%20%20Pulse%20Width%20Modulation.pdf
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00041736.pdf
