how to control the 8 wired stepper motor by using the GPIO !
maxcmp
Hi all,
i doing a project which is control the stepper motor by using GPIO.
but i felt confuse between the 6 wired and 8 wired stepper motor,are they can be using same method to control??
and also can i use the IC uln2003 to control the motor???
Actually there is no difference between 6 and 8 wire stepper motor. In 6 wire the common point of 2 coils is merged and taken out for control.
You have to use uln2003 to control the stepper. Directly interfacing GPIO will generate much more trouble
Nandhu
Re: how to control the 8 wired stepper motor by using the GP
Hi Nandhu,
thanks for reply..
may i request the circuit construct for the 8 wires stepper motor and the uln 2003??
Regards
max.
