How to control "primitive" for orcad pcb netlist export?
bnevins
I am using orcad to generate a pcb netlist for Design spark pcb.
Parts that are simulated with a subcircuit (opamps) have primitive = no for simulation, primitive = yes for pcb netlist. This controls the hiearchy descent in the netlist generation. Is there a way to
get proper netlists without altering this property for every part that has a simulation subcircuit?
Hey there
i have never faced this problem before, i always have my parts primitive property set to default and it works just fine! if you dont want to set each part to primitive individually, just select your design then click edit all objects properties and use excel sheet to mark them... you'll need 3 clicks only for your whole design.
But if you have a reason to keep that property determined please tell.
Ciao!
