How to control DDR RAM on motherboard?
samuelr
Member level 4
ddr ram control
I need to know how I might be able to use the /CS chipselect and also do memory access to one or the other DDR RAMs i have in the socket. Anybody any advice?
Thanks
MagixD
Junior Member level 1
ddr ram+control
Hello,
I'm afraid it is not possible to directly access the signals of the DDR SDRAM. Usually, if we are speaking about standard x86 technology, the memory is connected to a MCU (memory management unit) that is either integrated on the CPU (AMD), or on the Nordbridge of the chip-set (Intel). The MCU basically maps the virtual memory-space that is used by the CPU respectivly the OS to the physical memory-space (RAM, HDD, etc).
As far as i know, there is no possibility to hack or bypass the MCU so that you can directly control the SDRAM, indeed it is no good idea to do so, because the MCU also handles the whole memory protection and all that jazz.
May i ask why you want to directly access the control lines of your DDR SDRAM?
Best regards,
magixD
