How to connectl PIC16F876 and 1024Kx8 SRAM
salamander
PIC + SRAM
Hallo,
I want to connect my pic (16f876) to a huge 1024Kx8 Nonvolatile SRAM(Dallas: DS1270y-100), but I really don't know, how i could manage this both on hardware(-> how to wire, ?external devices nedded?) and software(-> I mean my c code).
thanks a lot
salamander
Hi salamander,
you have interface it parallel to your PIC.
1 pin for write
1 pin for read
1 pin for cs (not necessary)
8 pins for data
20 pins (2^20 = 1024) for address pins
I think that you do not have so much pins on the pic. So you have to use a extra device (latch).
How much pins are left for the connection to your SRAM?
by,
cube007
Ok, we have enough pins for direct connection :)
...but can you also tell me, how I can use the memory in c then? > assuming no file-system, just a big stream....
thanks a lot for your help
salamander
As far as I know:
You have to program your own access to the SRAM.
For example to read something:
1. cs = low
2. address pins to the desired address
3. rd = low
4. read out the data pins (complete 8-bit port)
5. next address
6. etc.
by,
cube007
Ok thanks a lot,
i will go this way.... - its an relative easy job for my project
thanks again
salamander
Hello salamander,
are you sure that you have enough pin on the PIC16F876. For a direct parallel connection you will need at least 29 pins!!! But the 876 is in an 28 pin package. Perhaps you should use the 877.
best regards,
cube007
It is right only for address pins, but you need 8 data pins, CS, OE and WR pins ....
Ok, I agree!
My replay is only for math problem in those post.
Mr.Cube
Ok thanks,
I will solve my problem on this way....
regards
salamander
