ripoo82
Junior Member level 2
- Joined
- Sep 18, 2012
- Messages
- 22
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,283
- Activity points
- 1,425
How do you connect the substrate?
Every building block I use has a separate net for Vdd, Vss and Vsub. The Vsub net connects to the Vss pad using a star connection. Since I assume that the substrate doesn't run any current, this is a small connection.
Is this correct, and if not, what kind of resistance is allowed from a building block to the vss pad?
