How to connect the strain gauge?
annchen
Newbie level 3
it is AD7730 is suitable for my project to do out the digital torque wrench?? i am using strain gauge sensor to get my torque value.
If use AD7730 already, i still need use op amp to connect to the AD7730??
Anyone can help mi? i very confuse its. :cry::cry:
FvM
Super Moderator
Staff member
Bochum, Germany
5V DC excitation can work without additional OPs, refer to the datasheet refernce circuits.
annchen
Newbie level 3
If i use ADC 0804, it is suitable for strain gauge?
FvM
Super Moderator
Staff member
Bochum, Germany
ADC804 will surely need an instrumentation amplifier. I also doubt that 8 Bit resolution is sufficient for a precision measurement.
annchen
Newbie level 3
how to connect amplifier and ADC 0804??
elecfan
Member level 1
Earth
I think you need to check the range of the strain gauge output, based on the sensor specification and the range of strains your system is experiencing.
for the best performance the sensor range should be equivalent to the ADC input range.
if ADC input is -5 to +5 volts for example, the sensor output should be amplified for such a range, to give the best resolution.
