AA,
How to connect the Bit RA4 in port A in 16f84A in order to use it as a data i/o pin?
As I understand from the data sheet, when it is programmed as o/p & the bit no 4 in port A is 0, it is connected to ground. when it is one it is floating? I want to use it as o/p pin & toggle the o/p .
Regards,
Amr Ali.
