How to connect power ground to chassis ground...
satish.ghariya
Member level 1
Noida/Indore
Hi All,
I am designing power supply and having DCDC converter module in it.
My question is How should I connect power supply ground to chassis ground. Can I use a ferrite bead between power ground and chassis ground.
Other any other better way of doing this
Regards
Satish
My design have DCDC to converter only
Is it possible to use ferrite bead /Inductor between chassis and power supply ground.
Yes you can use ferrite bead to connect between two different ground points
