leon30
Junior Member level 1
Hello,
I'm currently researching custom made photodiode and its possibilities for signal processing with the regard of an application as an integrated rpm detector (IC). How to connect the photodiode to the input of a fully differential CMOS OPAMP ?
Because this will be an integrated circuit I'm thinking to process the signal with opamp with some sort of offset cancellation technique with switched capacitors, so what type of opamp do you think will be suitable - voltage amplifier like folded-cascode or current feedback amplifier architecture ?
Thank you for your reply,
Best regards
Best regards
