May 28, 2015 #1 C chandankumar1331 Newbie level 1 Joined May 28, 2015 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 6 Referring to old thread https://www.edaboard.com/threads/199301/ avrsanju said: hai all,gsm modem sim300+pic without max232...(iam using 3.7 volt cellphone battery for pic and modem.) can i communicate properley with modem and viceversa?.i do not interested to use max 232,advice me pls.:!: Click to expand... hi i am building GSM sim 300 module for my my project .but i dun have any schematic and circuit diagram . can you help me . thanks Last edited by a moderator: May 28, 2015
May 28, 2015 #2 M milan.rajik Banned Joined Apr 1, 2013 Messages 2,524 Helped 540 Reputation 1,078 Reaction score 524 Trophy points 1,393 Activity points 0 If your SIM300 has TTL (5V type) pins for Rx and Tx then cross connect that is SIM300 Tx > PIC Rx SIM300 Rx > PIC Tx SIM300 GND to PIC GND (PIC should be 5V type). If your SIM300 doesn't have TTL UART pins but have RS232 port (DB9 connector) then put a MAX232 between PIC and DB9 connector of SIM300. If you need any help in coding then mention it.
