How to connect between two PC by using wireless?
meanvatha
Phnom Penh
I have a problem with connecting to another PC by using wireless. How can i do to connect with the wireless?
dude use blue tooth devices... and connect them in a network then u can access via each systems.... gud luck
you can use bluetooth for this purpose or
via a wireless connection you can establish network between two computers
If Wifi is what you're talking about, you have to configure your network adapter to work in Ad-Hoc mode. You can do this from windows' network settings.
That way you can communicate with both PCs without need of router.
Go to Ammy Admin and download the software. You can connect to any computer even if you are in another location.:cool:
you try this, start-programs-accessories-remote desktop and enable this option. if you connect your both systems in network you can access easy.
in windows 7 you can make your comptuer to be working as hot spot. This is only possible in windows 7 as it uses virtualization.
