Re: Adc0808 to PIC16F84A
@ansarmytheen,
If you check the datasheet of 16F84A, you will see that there is NO ADC. bogusmeister is asking for interfacing the 16F84A with an external ADC, namely ADC0808.
@bogusmeister,
I haven't used external ADCs, so don't know much about them, but this site should provide plenty of information:
However, I would say that it wouldn't be feasible as a lot of the pins would be required (8 data lines + more pins for setting), so not much useful stuff can be done. I would suggest using a PIC that has internal ADC. This would also make the circuit less complex since you would not required that additional ADC0808. Check 16F88 as it has equivalent pinout as 16F84A with 7 ADC inputs. Or more modern 18F series. If you go up the pin count, a PIC with 40 pins has more ADC inputs available, eg. 16F877A has 8, 16F887 has 14.
Hope this helps.
Tahmid.
