Hey guys,
Thanks for answers! The resolution will probably be no bigger than 640x480. I have very little experience working with PIC16F series controllers and NO experience working with anything else (1st year engineering student).
I just did some re-search on second suggestion and actually found this camera:
CMOS Camera - 640x480 - SparkFun Electronics. It apparently uses I2C interface. So i could hook this up to say 16F886 and WiFi module using UART. Correct?
I don't want feed from camera to be sent ALL the time, only when I get the signal to turn the motor on. Then I will start sending data from Camera to the server through WiFi module for the specific period of time.
Am I on the right path here? How hard is it to do something like this? I just want to be pointed to the right direction so I am not chasing a ghost here
Thank you very much guys!
---------- Post added at 18:54 ---------- Previous post was at 18:37 ----------
I still didn't buy any components so any suggestions on components would be greatly appreciated.
