Hi, I want to connect 2*16 LCD (with +5v logic) with STM32 (e.g. f030) microcontroller, as you know the GPIO output voltage is 3.3V. i found a schematic as you see below:
you see that except +5V power port all of them pull up with external resistor. is it correct? i heard from someone that we could connect them directly to stm32 without any pullup resistor,is it works?
another way is using BJT to connect 3.3v gpio to 5v signal whats your idea?
This is a frequently asked question...with a lot of useful answers and example circuits...
--> simply do a forum search.
General rule:
One device outputs the signals. The HIGH and LOW output signal levels are specified in it's datasheet. Look for V_OH and V_OL.
The other device is the input. The valid input levels are specified in it's datasheet. Look for V_IH and V_IL.
Check if input and output levels soecifications meet.
General rule:
thanks Klaus, first, I search in forum but cant find any useful data and then post this topic, maybe i dont choose good keywords!
I see the LCD Doc and it says it input works 4to5 volt but as i said somone told me that it works with 3.3v, this is the reason that i ask this question here to use from users experiences.
if you know what keyword should i search, please tell me. thanks alot
Option:
1. Connect directly and belive that it will work. (my choice, it works)
2. Connect directly and configure pins as OD (open drain), use pull up resistors to 5V (choose 5V tolerant pins)
3. Use level shifter IC (stupid way, it is made for 1.8v <-> 3.3v and to 5.0v shifting, 3.3v <-> 5.0v normally not use, if IO is 5v tolerant)
