How to configure the terminal to send AT commands to mobile?
Terminator Electricity
Member level 5
Hi ,, how to configure the terminal to write AT commands ????!!!
the phone never give any reply even when i give it only AT
i have a nokia6110 ..
so plz help me ...
Re: How to configure the terminal to send AT commands to mob
first, check the connections
second, check the baud rate
i have tried almost all baud rates,,
but there is few other options like
1- handshaking ,,,including RTS , DTR XOrs,,and none
2- parity ,,,
3-Emulation .. including TTY ....
and ....
is there any other sequence i should send to the phone through the terminal in order to reply with ok when i send AT ????
Added after 29 minutes:
i think I configured the terminal well ....
but everytime i type a variable ,, the phone responds with the same character!!!!!!!!!!!!!!!!!!!!!!
remember to set the phone to data i had same problem
6110 uses FBUS, if you need to use AT commands on it you need windows driver software that translate AT commands to FBUS, the best solution to your problem is to use 6210 or 6310 and DLR-3 cable, set UART to 9600,8,n,1
