chaitana
Member level 1
I'm using atmega8 with lcd nokia 3310.
When I use spi pin and some of portb as a control reset, ce and d/c. It's ok.
But I changed control to portc (only control not spi). Lcd not active.
I test lcd pin ce. It can't switch to hi. I'm check data sheet portc is adc port.
How to config port?
May I miss some hardware pin connect to vcc or ground?
How to config port?
