How to configure ATmega16 to run with external crystal osci
sino
Newbie level 3
I am an AVR beginner with ATmega16 as the Device. How can an ATmega16 be configured to run with an external crystal oscillator of frequency 7.3728 MHz. Which are the Special Function Registers for this purpose and how they have to be configured? What is the default settings? I am using CodeVisionAVR(2k evaluation) and also IAR Embedded Workbech Kickstart. Kindly help me with example C codes.
with regards
-sino-
nandhu015
Advanced Member level 5
India
Re: How to configure ATmega16 to run with external crystal o
Hai
Selecting External clock should be done with programmer
if you tell me what programmer are you using, then i can help you
It is done by setting clksel bits in fuse bits
Nandhu
sino
Newbie level 3
Hai,
I am using PonyProg2000 and the burning HW(AVR-PG1B. http//www.olimex.com.dev) was designed as per a free download and is using PC serial port.
With Regards
-sino-
nandhu015
India
Hi
Run PonyPorgrammer, select the device i.e. AVR => mega16
Press Control+s, You will see a screen with some check boxes
there you have to set cksel3 to cksel0
Please read carefully mega 16 datasheet (page25) before setting
CAUTION : SETTING WRONG BITS MAY LEAD TO CHIP DAMAGE
Take caution in settings
Regards
Nandhu
nipun
Member level 2
external clock can be set by setting CKSEL3...0 bits.these bits ve to b manually set using programmer and is done in different ways using the programming software u use.but be carefull not to mess with others bits if u dnt know there functions.read data sheet before setting bits
yadegari
Newbie level 6
in codewizard template of codevision software set CKSEL fuse bits
