How to compare two DLL's
mhamini
Iran-Tehran
compare two dlls
I need to know if their is any changes between two .DLL files (with the same name but without version...).
I can't compare by the 'time stamp' because always that i compile the dlls, it will change
how to compare dlls
you can use hex editor for that. You can try HexWorkshop. It has a trial version http://www.hexworkshop.com/. Or, if you want more features, you can use disassembler to compare the internals, if you know what "interfaces" changes (i.e. exported functions) within those DLLs. You might want to try the best disassembler I've ever known: IDA Pro. There's a freeware version at http://www.dirfile.com/ida_pro_freeware_version.htm. But, beware that it's not so easy to use IDA Pro. It's advanced tools. Only for expert.
    mhamini
compare 2 dll
Problem is well known as ‚DLL-Hell’ and isn’t so simple.
Please read follow links, maby that can help You:
hat is DLL Hell?
http://www.ssw.com.au/SSW/Database/DLLHell.aspx
DLL Hell
Escape from DLL Hell with Custom Debugging and Instrumentation Tools and Utilities
http://msdn.microsoft.com/msdnmag/issues/02/06/debug/default.aspx
Simplifying Deployment and Solving DLL Hell with the .NET Framework
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dndotnet/html/dplywithnet.asp
Tihi 8)
