Hi everybody
im working on my graduation project..and i need some help to write the code for my Pic,,
How can compare a data entering from the serial port, with a data already installed in the EEPROM,,and according to that ,some specific word will appear on the LCD?!!
more details:
An RFID reader will read some serial number out of a Tag,then it will transmits this number to the Pic (using the serail port, "RC7 Pin")...i want to compare this number with a data base "containing all possible serial numbers for the tags", and match only one of them ,then out this match on the LCD!!
i really need your help as soon as possible!!!
Thnx
Added after 8 minutes:
Sorry..i forgot to mention that im using "PIC16f877"..
Maybe i'm not absolutely clear but i think it's not a difficult job. basic algorithm can be like this:
let's say you are having 50 values in eeprom
1. start reading from 0 address of EEprom
2. read value of eeprom
3. compare this value with value received from RFID reader .
4. if same stop here, else increment eeprom address and got to step 2.(do this for 50 possible values)
5. show result on lcd
im using MicroC,but actually,im not expert in writing C codes..w i dont have enough time to learn it now:s..i'll be Gratefull if you can help me in the code itself, the syntax,Libraries,,,,cz these days im working on some other main part of my GP.
Thnx again
