how to communicate a 16 bit ADC chip with PIC 16F877A
irangathathsara
Newbie level 5
Please help me how can I communicate a 16 bit ADC chip with PIC 16F877A
If it uses SPI, just write a code for SPI communication, or used library functions.
Thanx for rplying,
ADC chip is MAX 1132 which support SPI, It is 16 bit and the PIc16F is 8 bit, i want to send data from ADC chip and read it from PIC.
Where would I find mikroC codes on this matter?
If you are have difficulties handling 16-bit data with an 8-bit microcontroller, attached is an appnote and code from Maxim. It demos an interface between 16-bit ADC to an 8-bit PIC. The interface is I2C, but you should be able to port it to SPI. However, finding MikroC specific code may be difficult. This project most likely will require porting code from one compiler to another.
  • AN2394-Maxim16bitADC.pdf
  • 1169_Assembly2.txt
