How to Comiple Multiple C source files in Linux
H_D_R
Full Member level 6
India
c++ multiple source files linux
Hello all,
i want to compile multiple C source files in Linux.
i am using Cent OS 5.0.
can any one please tell me how can i compile Multiple source files of C on linux.
please tell me that also how can i do same compilation process on linux using C++ files.
This tutorial might help you **broken link removed**
hi
$ gcc file1.c file2.c -o execute.out
enjoy
    H_D_R
If you are unable to understand the make files and the compilation process. You can use Eclipse IDE to get things done for you.
1. Download Eclipse IDE, from https://www.eclipse.org/downloads/
2. Extract the file... it does not require any installation.
3. Run Eclipse, make a new project.
4. Import all your source files using Import>Existing File system....
5. Build the project, and eclipse will create its own make files and u will get your source compiled.'
If you are using some extra libraries.. do let me know i will tell you how to mention about them in the include and load paths..
Hope that helps.
Cheers!
thank you to you all for your reply..
BTW, i have got solution of this problem but new problem occured.
can any one please help me to solve it.
it is posted @ following link.
Once agian Thank you to all...!!!:D :D :D
