how to collect 3.3v to 5v inside chip?
wateror
Member level 4
3.3v to 5v
I designed a chip with 3.3v/5v process. The digital part is working with 3.3v.
but the analog part need 5v power source, How can I raise the signal of digital output from 3.3v to 5v? Is there any good suggestion?
I tried a simple inverter. Though it can work, the pmos could not be shut down since the input is only 3.3v. There is some static current there. Is there any better method?
standard chips 5 volts
Instead of trying to boost the 3.3V, Simple method is to use a 5 volt for one section and then drop it to 3.3volts for use with another section. Dropping is easier than boosting. Good luck.
3.3v to 5 volt
yes, that's right. But my analog part need 5v dynamic range, so the switch signal have to be 5v. And my digital library use 3.3v circuits. There's no way for me to reverse it.
74hc voltage 3.3v 5v
you can use what is called a step-up dc dc controller
there are various manufacturers of such chips
you need a diode and an inductor also.
see for example maxim's chip
is it possible to raise 3.3 v to 5v
a clock doubler will work?
5v digital signals to 3.3v
Use voltage doubler or Levelshifter....
3.3v to 5v ic
I'm afraid you might took pranam77 by mistake. I think what he suggest is to use 5V vdd for analog part and then shift down to supply 3.3 digital.
Another solution might use charge pump to boost vdd, but that will be costly and the 5V supply noise will be terrible if not proper deal with...
