how to clock a 74595 shift register using pic16f84A ?
sukhoimg
Junior Member level 1
hello
how can i clock the shift register using the pic 16f84a to drive led matrix , i want to use the same clock as the pic ?
could you post your circuit? as I think you should not use the same clock as the PIC...
the common way is to generate the clock with a data pin of the PIC...
hello this is the schematic but when i simulte it it does not work , is there any error i'am not awear of §?
Post your relavent code for suggestion. Your hardware is OK.
