how to choose R C value in a rf Signal amplitude detect circuit
luciforlove
Member level 1
i know how to choose C58 by this
C*RL(Generally50Ω)≧(3~5)T/2
i use software to Simulation,find when r43 is changed,amplitude of V is changed ,but how to decide r43 and c59
RCinFLA
Advanced Member level 2
They depend on the desired demodulation bandwidth and output loading impedance. The 0.01 uF cap after the diode will also impact bandwidth of demodulated signal based on driving impedance and diode resistance.
luciforlove
Member level 1
just a 10MHz signal,and detect its amplitude
tony_lth
Advanced Member level 5
Beijing
You'd better simulate the circuit in ADS, then you can adjust the components to any values, and see the effect on the power detection.
luciforlove
Member level 1
actually i did it ,when rf amplitude is constant,R value influence output value(voltage),but i dont know if it is the reason that R is here,and how to chose R 's value
tony_lth
Beijing
After the power detector, if you connect to a OpAmp, the series resistor is always 1K~10K.
And, normaly, there should be a big resistor, say 100K, from the detector output to GND.
