how to choose CPLD or FPGA?
Laplace
Full Member level 1
how to choose a cpld
when you need to use a programmable logic, how do you make a decision on FPGA or CPLD ?
What is the complexity of your design?
How many of gates ?
You can use PLD also if the no. of gates is smaller .
Pharaoh Of Egypt
Cheap & small = CPLD
More expensive and bigger = FPGA
So it all depends on what you're trying to do...
IT'S a MATTER OF DESIGN
HI LAPLACE ..A CPLD IS SOMETIMES WELL SUITED TO REPLACE LOW COUNT NUMBEROF GLUE LOGIC..
IF YOU USE A BIG CPU AN OTHER FUNTION CHIPS THE CPLD IS THE WAY TO GO, ESPECIALY IF YOU HAVE TO MEET IMPOSED TIMINGS AND POWER REQUIREMETS ..
IF YOU NEED TO IMPLEMENT A PARTICULAR FUNCTION THAT IS TO COMPLEX TO BE TACKLE BY A CPU .. OR THAT WILL TIGHT UP THE CPU FOREVER THEN THE SOLUTION IS A SPECILISED CORE .AND ASIC OR FPGA .THIS DAYS .THERE ARE MANY POWERFULL SOLUTION FOR HIGH SPEED EMBEDED LIKE THE XILINX VIRTEX II .BU THE CHIPS GO FOR $200
SOME EPLDS GO FOR $2.. AND A CONSTELATION OF SOLUTIONS IN BEWTEEN ..SO YOU SHOULD FIND WHAT IS BEST SUITED FOR YOUR PARTICULAR NEED ..SPEED ,POWER,COMPLEXITY.
it depends on what you're trying to do .
you can simulate before choose chips.
what is more,speed,power,price are important.
It is simple problem.
if your design is more complex or is used to complete algorithm, you should choose FPGA, for this is its strongpoint.
if you only design a simple logic circuits or control problem, CPLD is enough.
