How to charge a 12V /40AH lead acid battery using solar panel ?
Jestin_cubetech
Advanced Member level 1
solar panel 12V 50W/100W
The easiest way is to get a charge controller that regulates the voltage n charge current into the battery. No worries of overcharging and overdischarging of battery.
thanks sunny55
actually i am looking for a solar charger circuit diagram.
There is one from TI by the model code BQ24650 which is a solar charger. Do check it out n see if its suitable for your application .
BQ24650
I'm trying to develop this circuit on a general purpose PCB, so that I can change the MPPSET and VFB level. With the same circuit above, when I tried to connect the battery, the circuit is shorting. The only reason I know is if the low side MOSFET fails, it could short but the MOSFET seems to be working. Can you tell me the possible reason for short circuiting.
N.B I've triple checked the connections and it is fine.
