you_rock
Newbie level 5
WINGMAN RUMBLEPAD joys
Hi everyone,
I have bought the logitch Wingman Rumblepad joystick controller as mentioned in the subject above and have found out that the slider (Throttle control) on this joystick can actually control engine speed in some games. (correct me if I am wrong?)
Now, one thing that I would like to do is change the RANGE of this slider.
Let me explain, apparently, the slider can go about 4.5 cm or 5.0 cm (maximum) (as indicated by the scale marks on the joystick itself) but let's say I want to change this value to about 10.0 cm maximum (for example to get more game engine speed)
In this problem do I have to change the actual circuit inside the joystick (so, open it and add some compononet to change the circuitry) or do I need to program it using a microcontroller or FPGA ?
If anybody can help me on this that would be great. Please give me some information as soon as possible because I need to finish this soon.
Any help is greatly appreciated and correct me if I am wrong anywhere also let me know if it can not be done and suggest something that can be done instead.
Thank you very much everyone and hope to hear from any of you soon.
cheers,
you_rock!
Hi everyone,
cheers,
you_rock!
