For Spectre (Analog Artist)
Plot Id vs. Vgs.
Using calculator plot deriv(Id).
Divide ("/").
In Waveform window select Axis -> X Axis -> Plot vs. and change from "Independent" to "deriv(Id)/Id".
Good luck.
first
.dc vgs start stop step
.probe par1=par('2*i(m1)/gmo(m1)')
after simulation
Awanwaves->Result Browser->select par1 in curves
then in 'current X-axis', click 'Apply', this change X-axis from 'vgs' to 'par1';
double click i(m1) in Result Browser,you will get
X-axis: par1
Y-axis: i(m1)
That is a method in spectre. If you want to change x-axis in csope, as I know, there is no good method. I always do like that:
1 plot two waves in same graph, one is A, the other is B
2 if you want to change x-axis to A
3 right click on name of A(on the right side of graph), choose view->horizontal vlue->real
4 then there will be two x-axis in this graph. one the the original, the other is A
It's not convenient like awaves.
