mitch81
Member level 1
hi,
i'm designing an horn planar antenna with HFSS! but i can't use my solution setup (16Ghz) because simulator said: "an extremely large mesh will be required to produce an accurate solution" (see the document loaded).
with antenna dimensions (24*60*12)mm, i can use 16 Ghz solution setup BUT with (90*210*12)mm, it's not possible use 16Ghz solution setup
HOW TO CHANGE MESH PROPRIETIES?
please help!!!
please help!!!
