how to change incident power in HFSS
Chourizo
Junior Member level 2
Spain
Default incident power is 1W. How to change it? Maybe adding more wave ports with different phases?
What is the scale factor defined in the port?
The power input can be changed in the following menu :
HFSS/Fields/Edit Source
Thanks for the reply, Hash.
I can only change the phase, offset and scaling factor, but not the power. Maybe it´s because of using wave ports.
Changing the scaling factor, you will change the power amplitude !
    Chourizo
Hi friends,
Can you please tell me. how can I find the impedance for the wave port, for which I have calculted my S Parameters.
Or How can I find input impedance of my model.
Its a simple circular waveguide, excited with two wave ports on each end.
hi friend
how do you use wave ports in your circular waveguide?
There is a quantity called "Port Zo" which is the transmission line impedance for the port. It appears in the list next to S,Y,Z parameters.
Adding further to a similar query, how do we change the amplitude of the ports in CST Microwave Studio?
