beakie
Newbie level 2
Hi, I am new to eagle and can't solve a problem I have encountered.
I have a single sided board from a Velleman kit. I am trying to replicate the board using eagle.
Eagle has calculated the shortest airwires but these are not the airwires the board uses. When I use autorouter, it only matches 94%.
I can see the layout and although I can draw them manually, I would like to work out how to get eagle to draw it for me. I can only assume the shortest connections are not the connections that need to be made.
Is it possible to change the airwires that are connected differently from the board I am copying?
I have attached the schema & board from eagle and images of the kit i am trying to replicate...
thanks
thanks
